GPS working or not working?
3690861115?profile=original
From the above picture, i have managed to telemetry from my configurator to my arducopter. I read the configuration of my Arducopter that shows me the GPS lat, long, alt data, but my APM/IMU led C is blinking red instead of stable red led.
Was my GPS working or not working?
  • Hello!
    I'm not sure that my GPS Mktek 1.6 is logged to my IMU.
    When you power up your IMU,  is the B led on or off? Mine is off. But after some minutes blue Led from GPS stops blinking and becomes fix. B Led is always off. Is it normal?
  • Martinit; I am using the Mediatek GPS v16.
    Darren; i am indoor, but i place my gps outside to check whether was the code working. therefore i cannot fly with the gps hold without a fix?
    Sebastian; yes, i am in sengkang. Thank you as least i know my gps working, but no fix mean no gps hold?
    Chris; i had selected the mediatek v16 option.
    To confirm that no gps fix = no gps hold?
    Have you selected the right GPS module? If it's a recent MediaTek, you need to select MTK16
  • as darran said, it didn't had a lock, but it gave out position data (are you located in Sengkang? if yes, your GPS is working)
  • Fix 0 means no lock. it looks like it had 3 satilites, but hadnt locked in yet. were you outside?
    What GPS unit are you using?
