Green vs red shield board
I have the green board so the photos on preparing hardware don't align with this board.1. Where does the 1-pin power pin for the telemetry go. Perhaps in the "5V" hole near the upper right corner?2. Where does the reset switch go? Probably across the "RST" and "-" surrounded by a rectangular box.3. Where does the 3 pin black wire jumper go. You need three pins on the board somewhere. The illustrated jumper on the red board fits on 2 pins.
  • Figured out, though it is not said anywhere, that the 3 pin jumper assumes that you will solder half of a three wire female servo extension in the pc board rather than a two pin header. Then the included 3 wire jumper male plugs into the 3 wire extension shorting white to black.
    I think you mean red vs. blue? The blue one is the new one. We're updating the instructions, but in the meantime, this picture should show you what you need.
