I have been using the GWS gyros for sometime but would like to be able to modify my own. The GWS is a plug and play device that goes in serial with the servo and helps stabilize your flight. I am making lighter ones for use on a small ornothopter. The problem is I dont know what exactly the output is or how to process it to control the servos. I just need the idea really not the exact design. If anyone knows anything let me know. Thanks.
All that happens in a GWS gyro is the voltage from the gyro element makes the PWM pulses fatter or skinnier as it increases or decreases beyond a user calibrated neutral point. The way you correlate voltage with duty cycle is usually a 555 timer but those are expensive, so those Chinese geniuses did it using discrete components.
