What kind of weight could I expect to move with four AXI Gold 5345/14s, or four Hacker A50-14L 8-poles or similarly large motors? I know the battery sizes will be heavier too.
I am trying to get help on finding info on motors, prop sizes (18 - 21"??) and overall limitations/lift requirements of motors and batteries for a 30 - 40 lb platform. Flying time of course would be under 30 - 40 minutes.
I know this is going to get expensive as four of the Hacker motor/ESC/Battery combos is around $3300.00.. Cheaper ideas with similar power are welcomed.Will the APM and mated electronics handle a platform of this size this the same as they would a 1/2 pound drone?The Freewave radio system is very interesting too.
If I can get a reliable and stable flying platform, I will go further with all of the cool ideas that are on DIYDrones.
Thanks in advance for assistance or help in any way.
https://youtu.be/t0A6qdpEFIQ
Denny Rowland said:
Denny Rowland said:
As long as you are using a standard ESC it doesn't matter what the size of the vehicle might be.
The reaction to inputs is a function of the PID tuning. Fast response is a function of how much power you have in reserve. If you are committing most of your power to lifting you don't have a lot of reserve for maneuvering.
As with anything that lifts you run into a weight spiral. "I need bigger batteries, and they weigh more so I need more lift so I need bigger batteries . . ." You will have to pick something that you think will be in the range that you need and then calculate total lift and then start subtracting all of the things that support that lift. Nothing but fun.
The 8 rotor in the second picture by Denny could be flown as a 4 rotor for maneuvering with the other 4 in a throttle only mode for lift.
With big motors and props like you're describing I'd be worried about moment of inertia making the system response sluggish. At the very least think about variable pitch with the motors running at constant speed.
A single rotor helicopter lifting 40 lb would have a rotor diameter of around 2 m, maybe a bit smaller if you wanted to compromise efficency -> rotor disk area = 3.14 sq m. Four rotors with the same area would have a diameter of 1 m each.
http://us.vario-helicopter.biz/shop/product_info.php?cPath=23&p... should give you an idea of the scale of these things and the power required.While the link points to a scale model, its weight and flight envelope is in the class you're looking for.
Once you to large model helicopters the efficiency of a single rotor turning as slowly as you can manage is going to be an advantage, particularly if you want it to be electric.
