Hello to all! I ais a problem with my arducopter 2 .6. He it in the red light flashes and which then remains red. And when I connect him(it) to mission to smooth an error message to apparrer by saying
Bad gyro Health
Here is if somebody can help me I thank him
Goodbye!
Hi Wilfried, the first thing to check is the 3.3v regulator, here is a link to Randy's post about the problem, the first video shows you how to check if the 3.3v regulator has blown.
If you can do this test first before we try other checks.
Martin, Je ne pas parle francais tres bien. :)
Hello! I have just tested and I one tried who varies between 4.25V and 4.35V. thank you.
Hi, does the red light flash the same as on Randy's video, if so it looks like the regulator has blown, can you return the board to get it fixed, or are you able to solder in a new 3.3v regulator yourself?
Bonjour! Les flashes de lumière rouge alors qu'il reste rouge et oui je suis à mesurer pour changer cet élément. Merci!
PS: I have just verified and I obtain 4.95 V
https://www.youtube.com/watch?v=IBBdm6zBaqs&feature=youtu.be
the problem in movie
Have you tried resetting the board and reloading the firmware?
No because I not it is not how to reset the board of reloading . Thank you !
Hello dessoler for the delay
I ais tested this solution and That does not still work
Thank you
You have to use the terminal page in Mission Planner, here is the wiki page.
you use the command setup/reset.
