Pixhawk Crash Analysis
Date:19-05-2017
Time: 4 – 7 p.m.
Weather: Calm, sunny day & with no or little wind
Temp: 37-32 C
Plane: Volantex Ranger
Board: 3DR Pixhawk loaded with plane 3.7.1
Battery: DIY 3s pack 20400Mah made from Panasonic ncr18650b
After programming the board, today was the first test flight. I took off in manual mode, trimmed the plane and flown it for almost 10 to 15 minutes in manual mode without any problem.
Then I switched to FBWA mode the plane handled the flight very well with the stock parameters and without any tuning at all. Then I switched to FBWB mode and the result was great flight. After that I switched to cruise mode where I faced only one issue: The plane was holding the flight path really well but with some roller coaster motion (something that I know is having to do with tuning). After that I switched to loiter and the plane started performing good circles thought I haven’t calibrated the airspeed yet. Only then and after making sure that the plane can fly itself I switched to RTL mode and the plane came back to me and started loitering at 200m altitude which I had set for RTL altitude.
Now it was the right time to start the auto tuning progress. I went ahead and did the roll tuning, then the pitch tuning and everything was good. After that I checked the tuning page on my mission planner and the parameters were changed to the new set of the auto tuning. Afterwards I started applying rudder inputs to tune the yaw and here the problem started. After few rudder inputs the plane stopped responding and went into a turn towards the ground with the rudder stock in one end. While the plane was going down I switched out of Auto tune and tried all the modes but without getting any response from the plane even in manual mode.
It was at that moment when the plane sat on the green field about 500 meters away from me. When the plane hit the ground the radio announced “RSSI CRITICAL”.
When I reached the plane opened the canopy the led indicator of Pixhawk was indicating failsafe. The plane wasn’t damaged at all and I didn’t notice any damage to the electronics as well. Of course I haven’t checked anything yet.
I had the screen recorder on my laptop recording the screen and now when I came to see the last seconds before the crash I realized few things that I wasn’t aware of as I had the sound muted on my laptop.
31’ 20” in to the flight started the yaw tuning
31’ 27” in to the flight 3 yaw inputs so far
31’ 28” in to the flight bad AHRS
31’ 29” in to the flight error caused vert variance
31’ 36” in to the flight 6 yaw inputs and I realized that something is not OK with plane
31’ 39” in to the flight warning no data for 10 seconds
31’ 40” in to the flight changed to other modes
31’ 44” in to the flight earning no data for 15 seconds
31’ 46” in to the flight I was sure that the plane is not responding at all
31’ 55” in to the flight warning no data for 25 seconds
32’ 05” in to the flight RSSI critical (from Taranis)
32’ 08” in to the flight Telemetry lost (from Taranis)
32’ 21” in to the flight Telemetry recovered (from Taranis)
32’ 23” in to the flight Telemetry lost (from Taranis)
32’ 42” in to the flight No RC Receiver
Error caused vert variance
Bad AHRS
Error compass variance
Same errors continued for several minutes till I reached the plane and turned it off.
Telemetry Recovered, RSSI critical, Telemetry Lost, ….
Now when I connect the Pixhawk to the PC I get a solid red light and I cannot get it to connect to mission planner.
I’ll try to go through all the components one by one to see if I can detect any error or issue starting from tonight.
Guys, please give me your thoughts and ideas on what could be the cause
Many Thanks
If we rule out the power supply as the cause, that would indicate a random component failure on the Pixhawk.
Since you aren't using any non-3DR components, there would seem to be no other possible causes.
Well, all the components that I use are from 3DR. I don't use anything clone, so the Power Module is a genuine one and I've tested that as well as the GPS, the airspeed and everything else that was on the Ranger and all of that works fine. As for the backup power yes I do use the servo rail as a backup power and I normally power the servos from an outside power unit so all the power that comes to the board is being used by the Pixhawk and the sensors only.
Mark Whitehorn said:
My guess is that the safety coprocessor, or a related component has failed. I'd replace the Pixhawk and make sure that its power supply is reliable, since there's a chance the failure was caused by a spike on the power input. Are you using the servo rail as a backup power source?
Tom Pittenger said:
Yes I have tried every possible way that I found online including booting with the safety switch, but I couldn't get it to work.
You suffered a power/hardware failure during flight. Have you considered you're suffering from a power/hardware failure now? Might be hard to get your replacement shipped to IRAQ though...
Have you tried booting with the safety switch pressed?
I've tried several different SD cards and even different firmware yet I'm unable to get over the error. I've also search online and all the same errors remained unsolved except for few that did flash the Q Ground Control Px4 pro, a trick witch didn't work for me. I was wondering if there is any other reason and/or a solution to this error?
usually thats related to a bad or missing SD card
Mohammed A. Shakir said:
Here is the Tlog File.
Many Thanks guys for your hard work and help
2017-05-19 17-50-28.tlog
1
2
3
of 3 Next
