Specs:
Mission Planner 1.3.16 build 1.1.5456.14788
Pixhawk running newest software (as of 1/29/2015)
Configuration: Y6
ESC: EFlite 10amp PRO; also tried cobra MR12B 12amp
Motors: EFlite Park 300 1380KV brushless outrunner motors
THE PROBLEM
     The ESC all-in-one calibration works to calibrate the ESCs but does not stay calibrated after the battery is unplugged and plugged back in after 15 seconds.
Things I have tried:
     I have tried to connect them to a separate radio receiver and will sucessfully calibrate.
    I have tested a connections for possible shorts/breaks in the system, everything is connected tight and properly connected to the pixhawk.
    I have tried seperate spektrum radios and different receivers connected to the pixhawk and will have the same problem.
    I have done all I can possibly think of to keep the calibrated the escs but pixhawk does not save the calibration.
How to help:
   Any and all help/suggestions will be appreciated. I will continue to post progress and pictures if it will help.
