Hi all,
I finished my Tarot X6 960 frame that I will use for experimental purposes.
I need to open the upper plate to shorten some cables and I found that almost all of the M3 screws that go into the spacer are stripped because I used too much thread locker when I mounted the copter.
How can I remove them? I have spare screws and spacers but I don't know what's the best thing to do to avoid any damage to the carbon plate.
Is there anyone of you that tried to make a hole into the screw to break its head, or cute the spacer?
Please help, thanks.
Ok I will try, thanks. I will use a pliers even if the head is very thin and some of them should also be rounded heads.
