HELP installing props
Hey,
I have these motors  http://store.jdrones.com/product_p/ac2836358.htm
with these props  http://store.jdrones.com/product_p/ac1245bl.htm
i've read the instructions on props install,
but the washer/spacer they put there inside the prop (seems like the 2nd biggest of the set) doesnt even fit the threaded shaft.
http://diydrones.com/forum/topics/propeller-install-notes
the problem as described in the following pictures....
please advise !
3690863315?profile=original
3690863148?profile=original
  • OK, i see it happened to more people, using the same motors and props from jDrones ??
    the reamer i saw had 6mm, 7mm, 8mm and 10mm.
    I just measured precisely the elements:
    threaded shaft: 6.1mm
    thicker part of the shaft - not threaded, seen on the second pic of the post :6.3mm
    prop very inner hole: 6.17mm
    from the measuring i learn that this thicker shaft is only 0.13mm thicker than the prop inner size,
    that should easily fit with the prop being plastic.
    i tried to push it hard on the shaft exactly like the second picture on the post, without the bottom aluminum 'base' locking part (just to see if it would go over the thicker part, and after applying some force it did.
    i believe this needed force would be applied naturally when locking the prop hard with the spinner/locking part.
    so problem solved.
    the thing is that this is not using a ring.
    the biggest ring has inner diameter of 7.95mm, the next one has of 5.95mm
    ideally i should have a ring that is slightly bigger inner diameter than the prop one, 6.17mm up to the thicker shaft dia. 6.3mm.
    i can drill the 5.95mm or any smaller ring to become 6.3mm, but the reamer doesn't have 6.3mm, only 6mm....
    now, if the balancing/angle setting of the prop is done by the two aluminum bases of the two parts between which the prop is locked, i probably don't have to worry too much because it will ensure being parallel and at right angle....
