Hello Diydrones!I'm a little confused with some components I need to buy and use! I'm a little new to APM so please bear with me...So far I have on order:Basic Breakout Arduino Multiwii BootloaderArduino JY-MCU Bluetooth Wireless Serial Port ModuleSingle TTL 3DRobotics 3DR Radio Telemetry Kit 433Mhz for APM APM2 APM2.5I know I have to change the baud rate on the bluetooth module, is the FTDI breakout board correct to do this?My second question is my telementry for the ground has a USB port so I need to find the pin out to solder on the connections to the bluetooth module does anyone have the values I need to find?I would like to use both my Samsung galaxy S4 and Kindle Fire HD (not at the same time though)Thanks for any help you can provide! So far enjoying APM!Cosha
Hi marcin,
Schenoni using a ground module, is it necessary to cut the wires going to the ftdi chip, or can be soldered in parallel , tx and Rx ?
It's still a work in process I keep hitting little walls! So far all I have really managed to do is change the Baud rate higher that my Arduino can read (15800)
No idea how to revert it via the Arduino!
Currently I just brought a 'On the go' cable (OTG cable is around £4 on ebay) that i plug into my Samsung Galaxy S4 and I just plug the USB module into that!
I havent had my quad up for a while time/weather etc...
remove FTDI
Sorry I can't be much of a help!
USB has 4 pins that I need fairly easy to solder too but I don't know what pins are what and I can't find the schematics!
Here a blog I have posted explaining how to do a bluetooth bridge:
http://diydrones.com/profiles/blogs/3dr-telemetry-module-recycling-...
