Help needed with in-flight tuning of PID-values
Hi all,
I have a question about the in-flight tuning of PID values.
According to this manual:
http://www.rcgroups.com/forums/showthread.php?t=1521520
I would like to start with tuning in the RATE_P values in acro mode. But the "tune=4" value affects only the RATE_P setting for stable flight, not for acro mode. But I want to isolate the RATE_P from STABILIZE_P to see the effects of chaning the rate value.
Is there a way to tune the RATE_P for acro mode? Or, if not possible, can I set the STABILIZE_P and STABILIZE_I term to zero so only RATE_P is used or would this lead to an instable flight?
Thanks in advance and regards
Marc
    Hi, I will make a version that tunes rate_P for both at the same time.
    If you can upload via arduino, here's the code:
    Arducopter.pde Lines 1880 (approx)
    case CH6_RATE_KP:
    g.rc_6.set_range(40,300); // 0 to .3
    g.pi_rate_roll.kP(tuning_value);
    g.pi_rate_pitch.kP(tuning_value);
    g.pi_acro_roll.kP(tuning_value);
    g.pi_acro_pitch.kP(tuning_value);
    break;
