Help needed with testing on Xplane
HiI have been able to sort most issues with the help of some members thnx for that. I am now at the point to test my flightplan /setup with xplane. I have 2560 board and oil pan with GPS. I have done setup through cli, and have uploaded waypoints to the board using AM Planner. Next step is to connect to Xplane, I have loaded HIL and made the suggested changes in Xplane, however when trying to connect i get - no sim data - 20. ....Any idea what i missed?
  • I have since gotten to the same point and yes experiencing the exact same thing, it would work perfectly and then next time no sim data, i have found that going into explane and changeing ip to another range and then in ardupilot sim, works sometimes, sometimes going back to 127.0.0.1 works. After reloadinf firmware and updates etc etc it does not solve the problem.....also sometimes my plane follows watpoints pefectly and then simply starts ignoring, waypoints stay in APM as well..
  • Still battling checked, xplane settings as per manual, still no luck....
    you need to redo the setup in xplanes check the wiki for the instructions
