Got my quad flying fairly well in stabalise mode, so I thought I'd try alt hold in my garden.
As soon as alt hold was selected quad went straight up to about 30mtrs and so i shut throttle and switched back to stabalise mode.
I just about managed to get it back down into my garden although I panicked and ended up breaking a prop.
I have attached the log, can anyone see what went wrong?
Thanks,
Dave.
Thanks all, the quad is now flying well in alt hold, loiter and RTL. Will try an auto mission on the weekend!
Have now put in some vibration damping and the improvement in the logs is pretty good I think. I have included the new log which I think now gives me +/- 0.15G in all three axis. I'm hoping that will be good enough. The big blip on the log is me flying into a tree :). Any comments are welcome.
2013-09-18 13-28 15.log
Changed the props from 0945's to 0845's and did another flight with IMU added. It seemed to more stable than before, but having looked at the logs I do have a vibration problem. I will try remounting the APM1 and see what happens. The throttle in for hovering looks like it's around 480, is that what I should set THR_MID or should I leave it at 460 which is rounghly throttle out?
The log is attached, any comments are very welcome.
Thanks, Dave.
2013-09-11 10-55 14.log
Hello, I have the same behavior and what I do not understand is :
* on stabilize, the accZ seems to be perfect (X & Y also) and the quad fly well - But sometime, as soon as I turn on Alt Hold, the accZ is x by 10 and the quad start jumping up (THROLin=465 and THROout=900). Which is the relation between accZ and AltHold, I mean why using AltHold make the accZ crasy ?
I concur with Chris - and had a look at the log, but there's no vibration information. You can clearly see that it climbs rapidly in ALT-Hold, and you did well not to panic and go into stabilise.
I'd turn on IMU logs, and do another flight in stabilise and look at the vibrations - you'll have some work to do, I think. More details instructions here: http://copter.ardupilot.com/wiki/ac_measuringvibration/
WpAlt negative during Atl_hold, strange.
Maybe not cause for this, but
THR_MID quite high 600, should be 350-400
Have you mounted the APM on vibration-damping foam? If not, Alt-Hold won't work (it uses the accelerometers).
