soldered the battery monitor resistors on the IMU shield. Soldering skill not so good. Using continuity test on multimeter, the 4 terminal pads away from the pins seem to share a common connection whereas the soldering pads row near the pins are not. Can somebody verify this before I power up and fry things. Thanks.
Here's the attached image just in case you miss clicking on the attachment
that's correct
