Posted by Derick Crook on September 22, 2010 at 11:52am
While I am an avid FPV and hobbyist robotics guy, I wanted to build something that I could take to the lake and send autonomously from way-point to way-point on the lake while maintaining long-distance communication. I guess, firstly, is the Ardu a solution to a simplified two channel (rudder and throttle) control system? I know that many of the features and components, such as the IMU and gyro, would not be needed to achieve long-distance water-based autonomy. But, considering the open platform and relatively low cost, I wanted to put it out there on this forum for some ideas from the community.
Any input is appreciated.
Thanks, -Derick
Since you need not control pitch or roll, I think just an ArduPilot board (no thermopiles or IMU), and a gps will be sufficient. If you want to get more sophisticated you could add a single gyro or a gyro and magnetometer... Depend on if you need a lot of precision. If you don't mind it getting off course line 5 or 10 meters every now and then, the minimal approach should be fine.
