Help with Radio Calibration
Hi All,
I'm currently running MP 1.2.7 and Arducopter 3.0.1 and when I move the Yaw and Pitch sticks nothing is sent to the motors. Throttle and Rudder seem to work and as I change the them the motors respond, but if I change the Yaw or Pitch no change in the motors occurs. I have erased the EEPROM, reset to factory, reloaded firmware, calibrated radio from the CLI and Mission Planner. When I go the Raw Data view and look at the radio, I see the values for channel 1 and 2 change, but on the output nothing changes.
I'm sort of at a loss as to what's changed. Everything was working fine, then it all just stopped.
Please help
Michael
  • Lets say your Elevator (Pitch) is CH1 on your receiver. Connect the servo lead from CH1 to the Throttle channel on the APM and see if you can get the throttle to move in the configuration screen.
  • T3
    Try moving your radio connections around and see if the problem is with the APM or receiver.
