hexa+ not working
I have gone through setup and set my frame to hexa+When I arm the motors only 4 motors spin. The front and back motors do not spin. Also, when I tilt the copter I was expecting the motors to attempt to level the copter which they did not do. Help please.
    Thanks for the heads up. I'm not sure we've tested that configuration, so we'll look at it. In the meantime just a reminder that issue reports should be made in the Issue Tracker. The developers cannot read all the comments here, so if you want it fixed, please file a proper issue report.
  • Yes, I'm getting the same results when testing the motors through the CLI.  I get no power to the motors when I'm in flight mode and arm the motors.  The green LED blinks, but the props don't spin.  I'm flying in hexa+ mode as well.
