high voltage reading in mission planner
Recently I update my Firmware on my apm 2.6 to the newest version. Then I completed the wizard then I went into config/tuning and loaded my parameter files to it.All said and done I went to flight data and it showed extremely high voltage readings(30 to 40 volts).So I defaulted the board and started from scratch and manually configured all my parameters and it happen again. After doing this several times on my last attempt i left the sonar disable and it was fine but if I enable it again the problem comes back. Is the a Issue with the newest firmware or ?
