HK GCS shows Target Alt = 0.0ft in Auto mode
I am using 2.24 + Remzibi Arduplane code.  When I fly the other plane, it works fine.  However, when I switch to a new airframe.  Whenever I switch to Auto mode, it would try to go to Target Alt = 0.0ft (as shown in the attached HK GCS picture).  I also attach HK GCS logs here hoping that you could help on what's the cause of premature auto-landing? ;)
I set the waypoints to be 200m above ground using Mission Planner 1.0.66.  And I did not check Absolute Alt.  I check Hold default altitude (which is 200m).  Please help.
Thank you.
Peter
0711111445.hko
  • Just to add.  I can read waypoints from 1.0.89 Mission Planner and see that I set the waypoints to be 200m above ground as well.  So I think it's not the Mission Planner.  Please help.
