"Homemade" HM-TRP 868 MHz identified as:
SiK 1.6 on HM-TRP
FREQ_868
In tool for Min Freq default value is 868000, for Max Freq is 869000, BUT in both dropdown lists I have:
902000
907500
915000
921000
928000
433050
434040
434790
435000
Is this correct?
PS. Same in Mission Planner...
http://vps.oborne.me/3drradioconfig.zip
I have a question ..... using a telemetry of 433 MHz can I change frequency to 900MHz internally using firmware or this is a hardware feature ... the datasheet says that "Frequency range = 240–960 MHz"
so are there variant of the IC itself for different frequency ranges or this is a single IC
I have just found this function in radio.c
set_frequency_registers
EZRADIOPRO_HBSEL
I believe this is the answer am I right
Check your calculation again...
Hi Marcin,
I think you will need to use the AT interface in a terminal program to set the frequencies. The 3DR tool that Michael wrote is meant for the 3DR radios, which don't (yet!) come in a 868 variant.
See the wiki page for information on the AT interface.
Cheers, Tridge
