  • Anyone have any more experience with this GPS?  I crashed today and broke my 3DR uBlox GPS....love to buy another one, but with all the other broken parts, I need to save where I can...so anyway, is this GPS from HobbyKing plug-and-play with the APM2.5+?
    Thanks....
    http://www.hobbyking.com/hobbyking/store/__33998__UBLOX_LEA_6H_GPS_...
  • Hi Iman,
    Did you have success with it?  I purchased one of those recently.  I used the 3DR config file with it and it appeared to work fine.
    I've been trying to get it working tonight with my APM 2.5.  However, when I connect with the HK supplied cable, and with the copter sitting on the bench, as soon as the Ublox gets a fix the accelerometers give really noisy data.  Doesn't help to move the GPS to a different position on the frame.
    Is this a wiring problem?  I don't understand how it could cause this noise, then again my knowledge of electronics is almost zilch.
    Colm
  • Hi Iman,
    Well if this one is "standard/original", will work fine with APM 2.5, even because 3DR Robotics also sell it in your webstore.
    Let we know if it's a good part, ok?
    Good luck!
    EDIT:
    I just take a look in HK website, and those LEA-6, has a bit different PCB, one connector more and it's made by hextronik.
