Hi, recently we bougth 3 brushless motors, a speed control, a rc control, but we dont know how to conect them.
Specifications:
-Motors brushless: Elite series exeed-rc, elite 370 63M02 20-30 kv5400
-Speed Control Bec: 5V/3A NimH 5-12s Lipo 2-4s
-rc control fly sky digital proportional rc system (ct6) 2.4ghz 6 chanels
-li-po battery Gens 2600mah-25c-11   1v-3s1p (11.1v)
3690931004?profile=original
  • A quick search turned up this post...http://www.rcgroups.com/forums/showthread.php?t=1142429
    Check it out. It should help.
  • Ok, Juan.
    A multi rotor helicopter has inherent instability, thus it wobbles alot along all axis of movement. Compared to a traditional helicopter which has only a single point of thrust a multi rotor vehicle has 2 or more points of thrust. To control the amount of thrust on any of those points you will need a speed controller per motor. A stabilising system, because not even the most proficient of us have the hand eye coordination to keep a multi copter aloft.
    You will need the following>
    A tri copter frame
    3 motors
    3 speed controllers
    An RX and TX with a minimum of 6 Channels (I cannot make out waht TX you have in the photo)
    Battery
    Connection leads for supplying power to each speed controller and the RX
    Connection leads between your stabilising system and RX
    APM or similar as stabilising system
    And finaly a lot of patience
    Start with searching fro tri-copters on the internet and also visiting the build logs in this form
  • What do you wish to do?, it seems you only have one speed controller for three motors, am I correct?
  • I believe you need 3 Speed controllers for 3 motors.
