How do I connect LEA6 to u-Center?
My GPS stopped working after a hard landing. Didn't seem hard enough to break anything though. The red light on the GPS module is lit, but I never get the blue "GPS fix" light.
I checked the GPS in the MP terminal and all the lat/long values are zeros.
I ordered the FTDI cable and the adapter cable but the adapter is only for the MediaTek GPS. It does not fit the LEA6.
How do I connect the LEA6 to the u-Center software on my computer so I can check the GPS and reinstall the firmware?
  • Basically follow the same method used to program in the special 3DR GPS configuration file which is documented here:
    https://code.google.com/p/arducopter/wiki/UBlox
    GPS <-> USB Serial Adapter
    GND <-> GND
    Vcc <-> Vcc (I believe most U-Blox GPS units need 5V power here)
    Tx <-> Rx
    Rx <->Tx
