  • On 3.0.1 Stable, the yaw speed is controlled by Acro_Rate_P, which also controls the angular rate of the roll and pitch rates.
    On 3.1 (in RC status right now) the rates have been broken out, Acro_RP_P is for Roll and Pitch only, and then Acro_Yaw_P is Yaw only.
    The way these work is basically 4500/100*P = Angular Rate in deg/sec.  So the standard P of 4.5, gives you 202.5 deg/sec.
