I seem to be unable to upload my code. I must be overlooking something.
These are my steps:
- slider towards servos
- connect USB cable
- start arduino.exe (code01.jpg)
- select my sketchfile (code02.jpg)
- copy paste the 2 log-parameters into APM_config.h (code03.jpg) (actually one was copy-pasted and the 2nd line I typed manually just to be sure no hidden characters are inserted)
- hit the save button
- hit upload
- done uploading (code04.jpg)
- unplug USB
- move slider to fly
- switch on TX
- switch on RX
- wait for GPS lock
- switch off RX
- move slider towards servos
- connect USB cable
- check serial monitor: enabled logs remain the same!(code05.jpg)
i erased all logs (is that necessary?)
i hit the reset button on the IMU shield (is that necessary?)
Which part am I missing ?
Wolfgang
Everything looks good, code loaded. Now where is your problem?
regards,
Wolfgang
