How to Add 2 more inflight Modes
I found a discussion for getting 5 switch positions out of channel 5 on a DX6i and it also works on my JR XP6102.  What I want to do is add 2 more switchable modes to Ardupilot 2.7.1 which currently uses these 3 position outputs from channel 5.  I looked in Ardupilot and see it uses a Case statement to switch between 3 modes, but I cant find anywhere where the low level stuff for channel 5 is even described.
It'd be nice if all I had to do was add 2 more #defines and 2 more case statements, but I get the feeling that the PWM values of the additional switch positions need to be stated somewhere.
Any clues where I need to make some changes.?
  • Here's the function that reads the switch and its found in the control modes tab.
    void read_control_switch()
     byte switchPosition = readSwitch();
     if (oldSwitchPosition != switchPosition){
      switch(switchPosition)
       case 1: // First position
       set_mode(POSITION_1);
       break;
       case 2: // middle position
        if (GPS_fix != FAILED_GPS){
         set_mode(RTL);
        }else{
         set_mode(CIRCLE);
       set_mode(POSITION_2);
       break;
       case 3: // last position
       set_mode(POSITION_3);
       break;
    Somewhere the PWM of POSITION_# is setup and that's what I'm looking for.  I'm thinking that mystery location is where I could tell it there are 5 different PWM values and then I could go in to the control modes tab and add 2 more cases.
