So if i undestand correctly i have to found a way to mesurate the exact airspeed of the airplane to found the exact value of this ratio for a data Velocity Vx .
a possibility is to calculate the Airspees by tree pitot tube and the use " a Media Pesata" (sorry i don't hot to translate in english is possibile as "weighted average" ) ?
I ask myself if the phone board in this case can help to solve this problems .
I don't think Martint answered your question. The differential pressure to airspeed formula we use in the code is inexact. The default value of the airspeed ratio was picked to give fairly accurate readings in the typical user flight speed range - 12-15 m/s. If you are flying faster you can adjust the airspeed ratio so that the measured airspeed is more accurate at higher speed.
The method you use to determine if your airspeed measurement is OK, high or low is up to you. The method by which you change the airspeed ratio is to simply change the parameter value using APMPlanner or another GCS.
Keep in mind that for 99% of applications, you would probably like the airspeed to be most accurate at the low end of the range, near stall speed. Error at higher speeds usually does not cause problems.
anks guys for the expalnation.
Ciao
Alex.
Alex,
