ok if turbine are that hard to control would you recommend rotary engine for this type of project.
i have herd that the best power to weight ratio engine are rotary engine, just look at the Sikorsky Cypher made by Sikorsky Aircraft it has just 53 hp made by a rotary engine but it can lift 300-340 lb (136-154 kg)
what turbine/turbine cnc plans would you recommend for lift 200 lb of cargo. it does not jave to be 1 turbine it can be multi turbine but all together well make 200lb of life power. Also when i say lift i mean vertically lift 200lb
if the JetCat P200-SX Turbine so bad would you recommend the Behotec B300F from http://www.altecare.com/behotec300.htm
so it could lift 25 lb at half rpm without a problem, just asking but what is static thrust is it just what is the max thrust a turbine can do?
Is it static thrust?
If so then this is how much it can lift less total weight of itself if used in vertical direction.
No doubt though this would be at full RPM and at say half the numbers would drop off considerably.
