How to change PWM values?
How do I change PWM values in MP?  When I calibrate my radio, the lows seem a little high (>1200).  Because of that I can't get to mode 1 with the F Mode switch and I think it might also be the reason I am having trouble arming the motors.  TIA, Greg
  • Turns out it was a bad RX or TX module.  Couldn't get them to work with servos either.  I replaced the Turnigy 9x modules with FrSky ones and no problems.
    Typically you'd change them on your transmitter side. Check to make sure you're not in some weird expo mode or have the heli settings turned on in your Tx.
