Hello,  I have a project which requires a gas tank sensor to talk to the APM 2.8   The gas tank sensor is the typical 0-190Ω variety like this:
one: https://www.amazon.com/Sending-Waterproof-Adjustable-0-190ohm-240-33ohm/dp/B09CYNP7KW/ref=sr_1_1?crid=2K4S4SEN21PN6&keywords=0-190+ohm+fuel+sensor&qid=1647602843&sprefix=0-190+ohm+fuel+sensor%2Caps%2C276&sr=8-1
I know Foxtech has a solution that is almost US$200.  Just wondering if there is a cheaper easier way do it.  I can convert the Ohms output to 0-5V, and change the code on the APM accordingly.  Just wondering if somebody has done this already
Thank you!
  • I want to know how to connect a 0-190Ω gas tank sensor to the APM 2.8 controller and I am glad I found your post where I found my answer. I am also very happy because when I was searching for it online, I also found https://www.topessaywriting.org/samples/composers website where I can read essay samples and the good thing is I don't have to pay anything to read them.
    Essays on Composers, Free Examples, Topics, Titles, Outlines | TopEssayWriting
    Free essay examples on Composers for students looking for paper ideas. Explore topics, summaries, outlines, and samples. Find your inspiration here!
  • Thanks Ben. I want to know how to connect a 0-190Ω gas tank sensor to the APM 2.8 controller and for that I am searching for it online and I am really very happy I found your post. I also found the https://www.topwritersreview.com/reviews/essayempire/ website link on a google search through which I can read reviews for an essay writing service. Now, I can easily find the best essay writer online.
    Can EssayEmpire boast of legit help and positive testimonials?
    Not everything is black and white. Meet the analysis of customer testimonials on EssayEmpire.com as well as reviews on other resources. Are you with…
  • Thanks Ben, We would like to change "Battery Voltage" to "Fuel Level".
  • I would use a voltage divider to convert the resistance in voltage, connect it to an analog input of the APM. Then you can read the value directly in Mission Planner by using the power monitor feature : https://ardupilot.org/copter/docs/common-power-module-configuration... Normally it's used to monitor battery voltage, but it can monitor any voltage on any analog input pin. Maybe it's even possible to translate the value to percentage, and have a warning if below a given threshold.
    Power Monitor/Module Configuration in Mission Planner — Copter documentation
