How to control yaw rate and yaw accel in auto?
I think the title pretty much says it all.  I'd like to control the yaw acceleration particularly, and the yaw rate while in auto missions.  Seems like there must be a parameter for this, but I can't find it.
Edit: maybe a bug?  I've found these:
ATC_ACCEL_Y_MAX: "Maximum acceleration in yaw axis"
ATC_SLEW_YAW: "Maximum rate the yaw target can be updated in Loiter, RTL, Auto flight modes"
They definitely have an effect in loiter mode - if I set my ATC_ACCEL_Y_MAX really low, I see extremely slow yaw acceleration.  However with the same setting, if I got into auto mode I get sharp yaw movements again.
  • I know this thread is a year old, but I was trying to figure out the difference as well, and I found the answer in the code changelog:
    3702386158?profile=original
    So, ATC_ACCEL_Y_MAX controls the max acceleration in manual flight modes, while ATC_SLEW_YAW controls the yaw speed in auto missions.
    Hope it helps!
    • It helped a lot. Thank you so much. Thanks, Thanks, Thanks, Thanks, Thanks, Thanks, Thanks,
