How to diagnose a wrong yaw setup with logs ?
Hello, i'm new with an APM2 and would like to know how to diagnose a Yaw problem with logs.
What logs do i have to activate ? Which value to check ...
In fact, i would like to know if it's possible with logs to analyse the PIDs settings
and if we can find what is wrong on settings by this way.
Thanks a lot for any informations.
  • Hello, now i have raw datas and can log Gyro X,Y,Z and Acceleration X,Y,Z
    but what can i do with those datas to analyze the good/bad behaviour of my setup ?
  • Thans to Redemptioner, i had a response ( On tuning guide post ).
    I wil ltry to add RAW datas on logs and see if it helps.
  • Sorry to "bump" the message but anyone has informations or links on how to analyze logs about bad parameters settings on Yaw or any other channel ?
    Thanks.
  • Anybody knows how to analyze CTUN logs or else ?
    Happy new year to anyone passing by here ... ;)
  • Hello, i've just found this on the wiki : http://code.google.com/p/arducopter/wiki/AC2_Datalogging
    It looks like the CTUN logs are able to give datas on gain loops.
    How can i use these CTUN logs to check gains ?
    Here is a screenshot of my CTUN logs : http://i11.servimg.com/u/f11/11/72/78/09/logsct10.jpg
    You'll want to examine the I terms if you want to see issues with Yaw.
    Yaw however is pretty easy to analyze without logs. If you set STB_YAW_P to 0 you will have no Yaw control. when you take off you'll probably start spinning indicating a frame is out of balance. Adjust your frame until your motors are all perfectly straight. Your copter should not spin on its own with STB_YAW_P 0.
    jason
