How to discover a crash reason - APM
Hello everybody!
I'm trying to discovery a crash reason reading a data log but I'm not getting out the reason, and I am asking for the help of you to find out why the fall.
The data log is attached  and I filmed the flight and fall.
Thanks for your help.
http://youtu.be/xAS1n9FoEfw
* The video will be available soon.
2014-09-26 18-04-32.log
2014-09-26 18-04-32.kmz
2014-09-26 18-04-32.log.gpx
  • a very clear mechanical failure.
    Not only from the log (plot ATT.Rollin and ATT.Roll from line 13950)   - but also from the sound and video.
    • Maybe some ESC cut by low voltage?
      • no,  that would look different (usually a huge instability while diffrent ESC's hit such threshold depending on load.)
        - and voltage was not that low
        - decent multirotor ESCs do not use cut-off.
        like john suggested: anything that makes one of four motors fail to deliver the thrust.
        anything between pwm cable, ESC, cables, motor, propeller mount and propeller.
        • Thank you so much @Andre K and @John, I will mount again and strengthen the mechanical structure of the quad.
    • that is what I was thinking too. Could it be a loose prop or faulty ESC?
