Hello , I set one up Pixhawk to accept 6s battery and is flying perfectly, but the OSD screen is showing a difference of 0.8 volts the actual voltage of the battery , so the battery alarm is triggering before the flight time they could get .
  Could anyone help me how can I change the value of Pixhawk battery alarm to adjust the difference?
Hug to everyone
  • Hello,
    How do you determine the "real" battery voltage?
    What power module are you using?
    • Hello, I determined with multimeter to get real voltage and I compared with OSD screen information. I modified 3dr module with 2s-8s UBEC.
      I need know where in Mission Planer, I can change the voltage parameter to modify battery low alarm.
      I don't have problem with this diference voltage, I only need modify battery low alarm parameter.
      Hug.
