How to set the EEPROM values
Last week I had a touch time trying to set the proper throttle failsafe PWM value. The default is 975 and i wanted to set it to 1030 . I put
#define THROTTLE_FS_VALUE 1030
in the APM_config.h and uploaded the code, but in the Setup>Show i still saw the old 975 value.
I then checked the EEPROM ( through APM Planner ) and saw that there the value was set to 975. A
I was subsequently unable to find any way to edit the EEPROM Throttle FS value and even though i tried to reset the board, I was not able to clear the value in the EEPROM ( I could only view it, but not edit )
Then, i noticed that in the new release of APM Planner, they gave the ability to edit the value of this . I was able to do it and got things to work, however this raised 2 doubts :
1. What if I want to edit other values in the EEPROM which are not editable in APM_Planner ? Or am I dependant upon the APM Planner to manage the EEPROM ?
2. Does the EEPROM value always override the config ?
Thanks much !
  • Yes I did reset (Setup>Reset on CLI ). But doesnt it auto reset the board when you reload the code ?
