How to stop circling around waypoints
During HIL simulation, with the aircraft  in AUTO mode, I find the autopilot circling around some waypoints. And sometimes it circles around all of them.
Any ideas how to stop this circling? Can the autopilot fly the aircraft close to a waypoint and then proceed toward the next?
HIL is otherwise successful ... with fully automatic take off and landing.
I am using APM2, ArduPlane-2.40, MissionPlanner-1.1.97,  X-Plane-10, PT-60 aircraft.
Thanks,
Mahesh M.3690947822?profile=original
  • Thank you for the info Tridge.
    @ Gábor Zoltán Here is a screenshot of the full autopilot HIL. It follows the flight plan so perfectly that the trace is totally overlapped. The simulation was for wind speed 0 in X-Plane-10. The way point radius is 127 ... needs to be optimized. I have attached the tlog of the flight.
    Mahesh M.
    3692469860?profile=original
    2012-07-18 15-57-54.zip
    https://storage.ning.com/topology/rest/1.0/file/get/3692469760?profile=original
    Hi Mahesh,
    For the next release (due in the next couple of days) this problem should be fixed, and it will not circle around waypoints even with a small WP_RADIUS setting.
    Cheers, Tridge
  • Hi Mike, Doug,
    Problem solved !!! Opening up the way point radius worked. I was using a radius of  10 m. For testing I increased it to 127 m and the circling stopped. I need to find an optimum way point radius.
    Thank you for your suggestions,
    Mahesh M.
    Most likely you have the waypoint radius too small.
    There is a new revision coming which changes the waypoint behavior so this will no longer happen.
  • For multi-rotors I found that a good compass cal and the latest firmware solved the problem for me. Also make sure that you declination is correct and locked in.
    Not sure if ArudPlane has a log cal option using the telemetry log but that gave by far the best compass cal for me and solved a lot of other problems.
    For airplanes I think that you can open up the way point radius so that it will switch to the next waypoint sooner.
    I am going to have my first airplane flying in about a week.
