Hydrogen-fueled uavs with long endurance
Narwhal2是一种四转子长耐久性氢燃料无人机,采用最新的金属双极板氢燃料反应堆作为主要动力源,具有更高的能量密度,显着提高的耐久性,以及更稳定可靠的性能。
机身采用高强度轻碳钎焊材料制成。
3691382724?profile=original
特征:
一体化手持控制台配备10英寸电容式触摸屏,运行Android 7.1,支持5.8ghz和2.4ghz的通信频率。
折叠式结构设计,节省初始云空间; 配备便携式背包,单人即可完成各种检查工作;
It can be equipped with a wide Angle camera, dual-light camera and 40X zoom camera, etc., providing services for the public security, electric power, petroleum, petrochemical and other industries in a complex environment.
Technical parameters:
Model quadrotor
The wheelbase 1060 mm
Rack weight 3.95kg
No load weight 7.25kg
The maximum load is 1kg
The maximum take-off weight is 8.25kg
Maximum no-load endurance: 110min
Maximum payload endurance of 80min
Power 800W hydrogen fuel metal battery +1020mAh lithium battery
The maximum cruising speed is 10m/s
Maximum climbing speed 2m/s
Wind resistance level 5
3691382932?profile=original
Hydrogen fuel cell unmanned aerial vehicle hydrogen cylinder
The special hydrogen cylinder for uav adopts toray carbon brazing full winding, with high performance and good stability. After the design of the composite material layer of the gas cylinder is completed, the simulation software is used to simulate it, so as to improve the consistency between the technology and the design.The thin wall aluminum alloy liner forming technology is adopted, and the wall thickness of the simple body is realized by the strong spinning and thinning process. LEIFFLD strong spinning and thinning machine from Germany is adopted to precisely control the thinning thickness through CNC program.
Working pressure: 35MPa
Operating temperature -40--+85℃
The blasting pressure is 70MPa
Fatigue life ≥500 times
3691383089?profile=original
Hydrogen fuel cell uav special pressure reducing valve
Hydrogen fuel cell uav special pressure reducing valve is developed based on the high reliability of aerospace professional technology. The product is light weight, easy to install, reliable seal, long service life, stable outlet pressure, low minimum inlet pressure, which can greatly improve the endurance of uav.
Special pressure reducing valve for uav
Rated inlet pressure: 400bar
Minimum inlet pressure of 5bar
Outlet pressure 40-70pa(optional)
Medium hydrogen
Product weight <200g
Geometric dimensions 78*77*47mm
The service life is >10000 times
3691383135?profile=original
Hydrogen refueling system solution
It is convenient and fast to safely inject the low-pressure hydrogen in the cylinder into the high-pressure hydrogen storage cylinder to provide oxygen for the fuel cell system.
Hydrogen storage and hydrogenation equipment
Outlet pressure: 35MPa
Inlet pressure: 2MPa
高安全性,自动停止运行
方便的电源和操作
机动性灵活,易于移动
  • yes
    Young said:
    Hydrogen is produced by hydrolyzing?
    Narwhal2是一种四转子长耐久性氢燃料无人机,采用最新的金属双极板氢燃料反应堆作为主要动力源,具有更高的能量密度,显着提高的耐久性,以及更稳定可靠的性能。 机身采用高强度轻碳钎焊材料制成。   特征: 一体化手持控制台配备10英寸电容式触摸屏,运行Android 7.1,支持5.8ghz和…
  • Hydrogen is produced by hydrolyzing?
