Channel one of my Rx has a y splitter servo cable which goes out to the ailerons and to the rudder. But when I turn the stick to a direction....the ailerons move to turn the plane the way I want it to go...but the rudder does the opposite. I can't reverse the channel because that would reverse the ailerons and then only the rudder would move in the right direction.... Is there a solution to this? Or do I have to go without a rudder?
    How many channels is your radio? If it's at least four you should just connect the rudder to channel four.
    Otherwise, I'd go without the rudder.
    Your going to get all sorts of weird secondary effects of controls if you fly rudder aileron on one stick, rather forget the rudder and make you craft aileron elevator or rudder elevator.
    Your Y cable is actually for using two servos for the ailerons, one on each side, not splitting it to rudder aileron, that's why one servo seems to be moving the wrong way.
    Normally one stick handles throttle and rudder and the other elevator aileron.
  • If you can not move the pushrods to the other side of the servo horn, then it is possible to get servoes that are going in reverse direction.
