I just joined this forum all but a few days ago so I am still trying to find my away about this website. I am not sure if I am posting to the correct area. Anyhow, I currently have in the works a design for a quadcopter capable of lifting a person around the 200 lb weight area and below. I plan on using four motors I found off of Alibaba.com- MP120100 80KV Sensored Brushless Motors (60 kg of thrust). Ideally, I am hoping to get out at most 530 lbs of thust. With the combined weight of the passenger and the drone frame and its components at around 270 lbs, the thrust to weight ratio would be around 1.9:1.
I have never built a drone before nor am I all to sure of how exactly to go about connecting all of the electrical components. The main problem I have at the moment if configuring a battery system which can support the requirements of the motors as well as the ESC and additional control systems. My area of expertise is far more mechanical by trade and I have little knowledge of electrical and technological functions.
The main frame of the drone is complete. It is modelled after the MK Airspeeder, something of an F-1 car design. I know I am a complete novice with this sort of thing, but I am eager to learn and hear what anyone has to say.
https://www.alibaba.com/product-detail/MP120100-80KV-sensored-brushless-motor-with_60469878298.html?spm=a2700.7724857.0.0.6c2574376XrfAk
Brand Name:
MP
Model Number:
MP S-120100/80KV
Usage:
BOAT, Car, Electric Bicycle, Home Appliance, electric paramotor
Type:
Giant brushless motor
Torque:
46Nm
Construction:
Permanent Magnet
Commutation:
Brushless
Protect Feature:
Explosion-proof
Speed(RPM):
7200
Continuous Current(A):
180A
Efficiency:
90%
Model type:
MP-S-120100/KV80
Power:
25KW
MAX AMP:
300A
KV:
50, 80
ESC:
22S 400-500A
MAX VOLT:
100v
SIZE:
120 x 100 ( without shaft )
Stator:
40mm
WEIGHT (kg):
3.9kg
SHAFT:
12mm
Certification:
ce, RoHS
MotorMPS120100KV80
Max power25kwRated power12 kw
Max current300AESC400-500A
Max voltage100vNo load current(15v)7A
Resistance160MohmSize120*100mm
Thrust58kg maxStator60mm
weight3.9kgShaft12mm
12198960675?profile=RESIZE_710x
  • Your being cheap yes it will work but 300amps is not enough 500amps is ok BL-heli firmwear ! better motors do not cheap out on your life ..
Aug 25
