Does anyone have some instructions/advices on soldering this GPS (http://store.diydrones.com/product_p/mt3329-01.htm) on the Adapter (http://store.diydrones.com/product_p/br-0014-01.htm).
Sorry if it's a trivial question, but I got none electronics knowledge, and recently purchased this GPS module with the intent to play it with Arduino (should have ordered with adapter or some breakout board). I just read the datasheet (http://www.gtop-tech.com/download/datasheet/FGPMMOPA6B-datasheet.pdf) after the purchase, and got scared with procedures like pre-baking and accurate control of temperature and time while soldering.
Any tips would be appreciated... if i can just get it to work with a breadboard will be a huge win!
Thanks,
Luiz Fernando Vital
    I did mine today, just like Peter said using a fine tipped soldering iron (30W) and thin solder, I added a little non acid flux and used a magnifying glass or specs to do it as they're very small pads, but the GPS has notches where the solder goes so it solders fairly easily
  • Whilst I don't have a Mediatek GPS I have handsoldered many similar components. Terms such as prebake etc are for soldering using an oven with solder paste.
    For hand soldering I would use a small bit on the soldering iron and thin wire solder. Align the GPS module with the correct pads on the adapter and then solder one pad by heating both the GPS and adapter pads at the same time and flowing solder to bridge the pads. Check that everything is aligned correctly and the first joint is ok and then solder the remaining pads. I would using a magnifying glass to check the quality of the joint.
    If you do not have some soldering experience I would recommend getting someone who has. Too much heat and too much solder can too easily create problems.
    Peter
