I want to find out if anybody is actually using this code to control their LED lighting? I am trying to work on a single, unified LED lighting program. I am thinking about deleting or completely hijacking Motor_LEDs.
I just wanted to know if that will really mess anybody up?
Is there documentation yet for the LED code built into the latest releases? If so, can someone point me to it?
I've searched high and low and can't find anything much that makes sense.
Where are the instructions for wiring up lights on a quad? I'm using the latest MP available firmware. I see I can just enable it in the MP but where are the instructions in the wiki for wiring up the lights to the APM1?
does anybody need gps status? i think the most important things are 1:armed/disarmed 2:battery 3:mode. i was thinking about something like this:
armed: leds on
disarmed: leds off
mode 1: repeated pattern ----------_- (1 short off)
mode 2: repeated pattern ----------_-_- (2 short offs)
mode 3: repeated pattern ----------_-_-_- (3 short offs)
mode 4: repeated pattern ----------_-_-_-_- (4 short offs)
mode 5: repeated pattern ----------_-_-_-_-_- (5 short offs)
battery first warning: repeated pattern ---___---___---___---___ (slow blink)
battery second warning: repeated pattern -_-_-_-_ (fast blink)
this way, theres only one output used for leds, they can be driven by the relay on apm1 and also, they are mostly on so theres no need for other nav lights.
Ok guys, I'm going to start the work shortly. I will try not to completely break this until it's working.
Steven, the final result will probably look an awful lot like what you have already done. That's along the lines of what I was already thinking. But thanks for your example because it will help me.
Really, the main point of this, is to make LEDS controllable from MP. Default will be off, but then you just change a parameter to turn it on, and change different modes.
Robert,
With each release, I modify the code (UserCode, UserVariable and one line of code in ArduCopter) to control external LEDs via APM1’s relay to indicate the state of motor arming and battery voltage. In my opinion, the Arducopter code should perform these basic functions out of the box. Any other function (like blinky LEDs) is nice, but I would turn it off.
Are you addressing these two indications (state of Motor Arming and Battery Voltage)?
Lloyd
No? Ok, well I will be hijacking the existing code and changing the name to Copter_LEDS. Will bring in some new functionality that people should like.
