Is PC joystick control working yet?
Hi,just updated APM Planner to 1.0.15 and went into the Joystick config. I'm able to assign the axis and click on enable. When I click on Save the dialog stays open. If I then go to the Raw Sensor View - Radio Tab, the output signals are not responding to throttle changes on the joystick. The APM is already unlocked via moving the RC Tx stick to the lower left and RC Tx inputs produce the normal outputs.Do I need to do something else to enable the joystick controls?Thanks,John
    By default on arducopter joystick is disabled, on planes it is enabled by default
    # define ALLOW_RC_OVERRIDE DISABLED
    Try the HK GCS instead. Joystick is still in beta on the Mission Planner
