hi,
i have a pixhawk connected to mission planner and am using it as an antenna tracker. i have two servos connected into a frame i rapid prototyped. the problem i am having seems so simple but i can't seem to arm my tracker. i get the green flashing lights on the pixhawk but i can't seem to get the solid green light. any help would be much appreciated
did you find a solution for that issue... i have the same problem
how exactly are you trying to arm it?
Keith, i managed to get mine working by reinstalling the firmware of my copter and then using the wizard to set it up. the only issue i have now it that gps connectivity isn't great.
Unfortunately its in the office. are you using a pixhawk?
i read somewhere that if you go into config and tuning in mission planner and then go down to the telemetry line, check all the values. they should be all be between 2 and 5. if you look at the HUD of the quadcopter, it should move and there should be a movement in vertical speed. otherwise the link is not functioning and it won't lock on. there is no arm button. it should arm itself when it connects to the vehicle
sorry but i am a beginner at this and could really say i sort of lucked into fixing it
