Jdrones 30A ESC problem
Hi
I have a hexa that works very fine, but one of the ESC seem to apply som kind of voltage. The reason i think this is because all the motors spin free before i connect the battery. After connected batt and armed the ESC one of the ESC spins up last and stops first. When i try to spin it with my fingers it feels like the motor is breaking ???
 I have tryed to recalibrate the ESC but no luck, anyone ???
  • Have you checked the brake setting on the ESC. i have all mine set to on, so if im about to crash i can cut the throttle and the props stop spinning before they hit the ground. has saved many a prop during initial testing.
    i think the lower 4/5 of the throttle range is braking and the other 4/5 is throttle, without the brake setting it is all throttle.
  • Just a question are these the 880kv motors?
    You must drill the hole in the frame larger because the C-clip on the bottom of the 880KV motors is larger and thus drags on the frame. You really should check this on all the motors as you will destroy them quickly!!!!
