I'd like to simulate a jDrones AC2830-358 motor using Simulink. I'm guessing, it's characteristics wouldn't be too different of many other engines with similar KV ratio, power and size. In DriveCalculator's database I found EMP2836/09 (880KV), which I suppose could be used for a decent simulation, or at least as a starting point.
I'd like to use a simple mathematical model given in one of the great CTMS Examples
In DriveCalculator, there are following constants I need given (or missing):
Kt = 1,142 Ncm/A (electromotive force constant)
Rd = 174,7 mOhm (electric resistance)
L = ??? (electric inductance)
J = ??? (moment of inertia of the rotor)
b = ??? (dumping ratio of the mechanical system)
I guess I can figure out the moment of inertia J, as I've got one broken engine I could weight / measure. Do you have any idea what L / b can be? I would be best to also take propeller characteristics into account (for example APC 10x4,7 http://www.ae.illinois.edu/m-selig/props/propDB.html#APC).
Tom
  • Regarding the inductance, L : That could be determined with a L/C meter or a specification not normally published by the manufacturer (as in most RC folks don't care).
    It will be necessary to determine the configuration of the windings of the motor - delta or wye.
    Delta/Wye
    Oh, is this an electrical simulation or a mechanical simulation?
    After rereading your query, it is starting to look mechanical to me.
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
