jdrones GoPro Camera Mount
Has anybody experienced metal screws of the mount loosening due to vibration?
I have not even able to take off my drone yet due to a bad legs shipment but after turning on the motors for testing for couple of minutes found out that one of the roll screws and one of the pitch had came off..
How you have fixed that?
Also, when loaded with the gopro hd, the pitch servo movement with the default servo provided by jdrones is very jerky.
Could this be beacuse the servo has not enough torque to move the camera?
What servos are you using?
Patricio
  • I have added some Loctite Blue to the screws. Lets se how it works.
    Any idea about the servos?
  • I guess metal screws should be fixed with blue threadlock, otherwise they will tend to loosen.
