Join 2 or more mission into 1?
Has anyone tried to merge (join) 2 missions? Not sure what I did will work, but this is what I did. Opened Mission 1 in notebook. Opened Mission 2, deleted lines 1 and 2, copied remaining text and pasted below the last line of Mission 1. Lastly, renumbered Mission 2 waypoints to be consequently from Mission 1 then save as new. I have not tested yet!
Thanks,
Brian
  • Yes, I've done that and it works well. You can also use the Load & Append option in Mission Planner, it's quicker. Watch out though, it always inserts 1 bad waypoint that needs to be deleted.
    • Thanks "iskess".
      This leads me to another question: Where can I find or can some one explain the " Load & Append" function in MP?
      I have looked high and low but no success.
      Thanks,
      Brian
      • Right click on the map on the Flight Plan tab.
        Select Load & Save, and then Load & Append.
        That is from memory, the text litany might differ slightly.
        Be sure you are using Mission Planner and not APM Planner.
