Kaspersky detects KeyLogger within MP
Can someone help me understand why Kaspersky anti-virus identified and deleted a DLL within a recent Mission Planner update that is defined as a KeyLogger. I had to disable Kaspersky for the update to download; I was getting an update failed due to virus protection error; but my night time virus scan found this DLL with the Mission Planner directory and deleted it. Why is it there? Does it matter that it was deleted?Cheers!Pem
  • Kaspersky advanced settings cause the malware affected files to be deleted directly without giving an option. Which is good for security measures but risky as it might delete certain program files. K7 Antivirus Customer Support can explain more on this topic. The firewall settings also perform certain access blockage.
  • This file is already present in previous versions of MP, but...
    from version 1.3.15 of Mission Planner : the file is 241152 bytes long, and no malware detected (not a single).
    from version 1.3.31 of Mission Planner : the file is 235008 bytes long, and malware detected by 15 antivirus.
    The weird point is that both file are version 1.0.0.6 so they should be exactly the same.
    It should be noted that this file is not developed by Michael Oborne, but by "Maxim Kartavenkov aka Sonic 2012". Who is probably someone reliable, but it's just to understand that it's a dll imported into the project, not a development from Michael so who knows what's really inside.
    PS : I didn't compare to all versions of MP, but I had version 1.3.15 laying around, it could be interesting to compare with other versions too.
  • I am using MalwareBytes and Avast here and no report of infection have been found coming from the Mission Planner directories. Furthermore, I am using the latest version of the Mission Planner on my PC. As it has been mentioned previously, it must be a false positive.
    Also, that .DLL file must have a certain line of code that is causing the AV to trigger it as a Trojan or Malware. If I were you, I would just report it to Kaspasky as a false positive.
    Hey Michael
    This must be what is going on with the false alarm :)
    http://www.torontosun.com/2015/08/14/antivirus-firm-kaspersky-faked...
    I have removed this dll from the current release of MP.
    it is no longer part of the MSI, or the zip, and will not be downloaded as part of the update process either.
    • This reply was deleted.
  • Scanner results:10%Scanner(s) (4/39)found malware!
    Time: 2015-08-13 07:29:30 (CST)
    Scanner Engine Ver Sig Ver Sig Date Scan result Time
    ahnlab 9.9.9 9.9.9 2013-05-28 Found nothing 3
    antivir 1.9.2.0 1.9.159.0 7.11.255.236 Found nothing 24
    antiy AVL SDK 3.0 2014112615531100 2014-11-26 Found nothing 1
    arcavir 1.0 2011 2014-05-30 Found nothing 11
    asquared 9.0.0.4157 9.0.0.4157 2014-07-30 Found nothing 1
    avast 150812-1 4.7.4 2015-08-12 Found nothing 32
    avg 2109/9918 10.0.1405 2015-08-11 Found nothing 1
    baidu 2.0.1.0 4.1.3.52192 2.0.1.0 Trojan.MSIL.KeyLogger.bzam 4
    baidusd 1.0 1.0 2014-04-02 Found nothing 1
    bitdefender 7.58879 7.90123 2015-01-16 Found nothing 1
    clamav 20779 0.97.5 2015-08-12 Found nothing 1
    comodo 15023 5.1 2015-08-01 Found nothing 3
    ctch 4.6.5 5.3.14 2013-12-01 Found nothing 1
    drweb 5.0.2.3300 5.0.1.1 2015-08-09 Found nothing 33
    fortinet 27.281, 27.281 5.1.158 2015-08-13 Found nothing 1
    fprot 4.6.2.117 6.5.1.5418 2015-08-11 W32/Felix:.NET_program!Eldorado 1
    fsecure 2015-08-01-02 9.13 2015-08-01 Found nothing 1
    gdata 24.3819 24.3819 2014-08-29 Found nothing 7
    hauri 2.73 2.73 2015-01-30 Found nothing 1
    ikarus 1.06.01 V1.32.31.0 2015-08-12 Trojan-Spy.MSIL.Keylogger 23
    jiangmin 16.0.100 1.0.0.0 2015-07-30 Found nothing 16
    kaspersky 5.5.33 5.5.33 2014-04-01 Found nothing 20
    kingsoft 2.1 2.1 2013-09-22 Found nothing 3
    mcafee 7879 5400.1158 2015-07-31 Found nothing 10
    nod32 1777 3.0.21 2015-06-12 Found nothing 1
    panda 9.05.01 9.05.01 2014-06-15 Found nothing 3
    pcc 11.850.05 9.500-1005 2015-08-12 Found nothing 1
    qh360 1.0.1 1.0.1 1.0.1 Found nothing 6
    qqphone 1.0.0.0 1.0.0.0 2015-08-13 Found nothing 2
    quickheal 14.00 14.00 2014-06-14 Found nothing 2
    rising 25.17.00.04 25.17.00.04 2014-06-02 Found nothing 3
    sophos 5.17 3.60.0 2015-08-01 Found nothing 8
    sunbelt 3.9.2589.2 3.9.2589.2 2014-06-13 Found nothing 1
    symantec 20150810.001 1.3.0.24 2015-08-10 Trojan.Gen.2 1
    tachyon 9.9.9 9.9.9 2013-12-27 Found nothing 3
    thehacker 6.8.0.5 6.8.0.5 2014-06-12 Found nothing 1
    tws 17.47.17308 1.0.2.2108 2014-06-16 Found nothing 6
    vba 3.12.26.4 3.12.26.4 2015-08-12 Found nothing 4
    virusbuster 15.0.985.0 5.5.2.13 2014-12-05 Found nothing 17
    ■Heuristic/Suspicious ■Exact
    NOTICE: Results are not 100% accurate and can be reported as a false positive by some scannerswhen and if malware is found. Please judge these results for yourself.
    Trojan.MSIL.KeyLogger.bzam - VirSCAN.org - Free Multi-Engine Online Virus Scanner v1.02, Supports 4…
    Trojan.MSIL.KeyLogger.bzam - VirSCAN.org - free virus scan is a free online scan service, utilizing various anti-virus programs to diagnose single fi…
    the source code
    https://github.com/diydrones/MissionPlanner/tree/master/ExtLibs/Bas...
    the library is for talking to windows directshow.
