Id love to get an idea what people are using for their aerial mapping Canon cameras. I have the Canon S95, which usis optical image stabilization (OIS). This means the lenses are floating and move around in a very finite level to adjust for your hand movement. This poses a big problem for aerial work when the vibrations are noticeable. The lenses literally vibrate and no amount of shutter speed can fix it. I get very poor results; most aren't keepers but sometimes they are depending on motor rpm. Ive tested this camera for years on many different platforms, tried every vibration reduction method and still get bad results.
So, I'd love to hear what you are using and how the results work.
Matt
UPDATE: Ive ditched the Canon s95 in favor of a Sony NEX-5R with an intervalometer app. Ill be using a Sigma 30mm lens.
I use ELPH 520, in a "waterproof" (not anymore) case, riding on rubber shock mounts. The pictures come out clear with no motion blur.
Seems a good alternative, plus you get a bigger sensor and better optics. The only problem is more weight and the higher price.
In my company UAVs we ever used the S line of cameras (started with s95, then S100 and now S110). And we never had problems with vibrations and blur. We run then on a small electrical fixed wing UAV, and also on a big 25kg UAV with a 5HP engine that vibrates like hell and never had such problems. I recommend all the folks said Tv Mode, 1/1000 aperture, 100 to 400 ISO.
Beside flying the camera, I have a S95 that sometimes I use while riding my longboard, and it generates very fast vibrations that not affect any of the photos that I took.
Perhaps you have a defective camera.
The first picture allowed me to see a missing roof tile (:
The Nex-5N is stunning! Shot some video with it today. No problem with vibration at all, I even left the OIS on!
I just got CHDK loaded and working on my A4000IS. Playing around with 1/100k shutter speed - works awesome in hand. Can't wait to bolt it up to the quad tomorrow.
Matt - Not much help here. But I started seriously using my Canon Powershot A4000IS and having similar problems (i.e., some shots are stable at certain RPM). I'm trying to download CHDK (Canon Hackers Development Kit) to see if the expansion of capabilities (shutter speeds) will help but currently no luck downloading CHDK.
I'll be monitoring this post for others suggestions as well.
Joe
Has anyone tried this camera?
Sony Cybershot DSCHX30V 18.2mp 20x or this one Sony Cybershot DSC-HX200V
Cheers M
S100 is gone, picked up the Nex5N for $329.
I really think the issue on the S100 is not so much the OIS, as it is the actual exterior lens barrel. It was very easy to move lens barrel by hand. While at the store, I played with the SX270, and it's lens barrel seemed quite a bit stiffer. Maybe that's why people have more luck with it?
It would be nice if we could get a good "tough" camera that would do what we want. The lenses should be much more solid.
1
2
3
of 3 Next
