Hello, I have my Lidar lite hooked up PWM to my plane (using Pixhawk). Small issue, getting readings but at its lowest point, when belly of plane is on ground (I have Lidar mounted under wing), it should read about .1 meters, thats 1/10 of a meter. It reads .5 meters. When i check something much higher like 2.5m it is almost spot on. Wondering why I am not accurate close to ground but after 1.5 meters its starts to get very accurate.
Thank you,
JEFF
FYI I am using 3.3 beta
